Two Lines Of Room Divider
SapPata
The room divider turns into an invisible Interior 4 wall when you change the structural properties on either side of the room divider. .......
Does this make sense?  I don't mean to say "does Tommy's statement make sense",  I am asking if the wall changing makes any sense.  BTW Tommy,  thanks for this insight.
Truly,  why would anybody want the wall to change to an invisible interior 4 wall because I changed the ceiling height on one side of the room divider.  This is the kind of stuff that must drive people nuts.
Select the Room Divider wall and open it's dbx.
On the General panel, change the thickness to whatever you want.
The beauty of doing it this way is that Chief will automatically create a new wall type that is invisible room divider wall and the thickness that you specified.
The new wall type is added to the will types list named something like "Room Divider-100".
The 100 is the thickness - 100mm in this case.
