Funky Molding Radius
Steve-C
Go to solution Solved by Greg_NY61,
I've been battling this for years, every time I create a 3d molding radius in an elevation it's never very smooth. It usually looks like a series of straight lines made to look like an arch. This one isn't too bad but I think the worst application is when I use it for a radius brick arch. Most of the time if it looks really rough I'll just CAD line it in. Does anyone know a way around this?
On a side note, if you have a polyline solid with an arc in it, you can select the arc, open the solid go to "Selected Arc", and deselect "Automatic Facet Angle" and select whatever angle you wish to make the arc appear smooth.
See Attached...
