Top Stair Material Change
HighwayMan55
A couple of questions on this post...
1) How do i change the material on this top piece of my stairs?  When I do it changes the whole wall.
2) How do I trim the trim to the height of the floor?
3) Can I change the height of the trim?
And lastly, can I can I select a different material for the trim than the riser?
Thank you in advance!
OurHouse.plan
Select the railing wall and apply a "Wall Covering" (10" high, -10" to bottom).
-or-
copy the "Wall Type" for that railing and add the riser material to the exterior surface.  In reality, the riser is there but the Wall Surface material is over-riding it in the display.
There's no way to specify a different material for the trim vs risers.  We've asked for that but CA hasn't done it yet.
-or-
Using the wall covering it spans the whole wall, not just the stair section.  And copying the wall type covers all the stairwell walls.  I think I will use a polyline, I seem to be getting good at using those to fake out things, lol.
So, FWIW - here's what I did:
1.  I broke the railing wall right at the edge of the Door Opening
2.  I selected that wall segment and used Transform/Replicate to move it in the y direction 1/2"
That allowed the riser surface to show because the wall surface was no longer in front of it.
I just went with the polyline solid.  I do have the riser surface at the top landing checked already.  I attempted Joe, but I was unable to without missing up other walls.
I've come to the conclusion that will not be able to "properly" recreate the way the house was built.  But I can come close.  Thank you all.
Fixed it just playing around, straightened a few things, added another break in the landing and brought it back from the upper floor just a tad.
Edit btw your rail walls weren't aligned with the wall below also.
There is a 1" overlap of the top floor over the bottom floor, that's why they aren't aligned.  I am doing a as built drawing of my house, and that's how its built for some reason.
