Invisible Room Divider Trouble
freshrooms
if I  remember correctly the room divider creates an "invisible wall"
which has layers and thickness
I think you can modify that room divider wall and copy it as a new wall type
give it a layer thickness of 1/16
but the polyline solid sounds like the best solution for this situation
Lew
Yes, how did you do that?
I simply took your invisible wall and moved it to accommodate a better wall to invisible wall look, see the second image I provided, showing how I moved your Invisible wall.  No need to mess around with poly-lines on this one.
