How To Change The Layer A Label Is On
betsybranden
How do you change the layer that a symbol's label is on?
I recentely imported a new light symbol into my library for a wall sconce.  Chief put it on an "Fixtures, Interior" layer, and the label is on the "Fixtures, Labels" layer.
I easily changed the fixture to be on the "Electrical" layer, but the label is stuck on the "Fixtures, Labels" layer and I can't figure out how to change it to the "Electrical, Labels" layer.
Any ideas?
Thank you!
Thank you so much - Alaskan_Son!  How do I change the symbol to an electrical symbol?  I dug around in the "Open Symbol" area and "Open Object" area looking to change everything I could to "Electrical" and couldn't find that.  Thank you!
Re-import the symbol.  Make sure to use the Import 3D Symbol option rather than drag and drop or copy/paste. During the import process, the Import Symbol dbx will pop up.  Choose "Electrical" from the drop-down list.
