Reduce Room Selection Priority..
Rashid_Garuba
This is likely a "duh, you must be over 50" and forgot" moment. On a daily basis while working on floor plans the Rooms select way too often and gets in my way.. Ideally a triple select to select Room will be great. Once the structure is established, I rarely need to select rooms...
A setting somewhere?
This is what I love about the Active Layer Display Options thingy ma bob. I always have that tool open and set to ---->post-170-0-06816100-1454509441_thumb.jpg
This will pop the selected objects layer to the front of my list and then I can quickly lock that puppy out so I don't keep making the same mistake and expecting different results (which happens to be the clearest definition for insanity).
