Presentation Of Live Elevations
Gawdzira
If anyone is bored and wants to experiment....
I am doing a test of the live elevations and line weights. See the attached pdf comparison to a screen shot. What I am trying to do is punch up the elevation lines on color elevations without cad lines. The elevations are set to watercolor and I removed the pattern lines from the shingles so it does not overwhelm the view. The problem is that when printed to pdf with either the CA save as pdf or a 3rd party pdf driver I am not getting any line weight variation.
CA files here
https://www.dropbox.com/sh/iull2034vnqirua/AADKvg2acyM2ZH5xdf4cgUyda?dl=0
LEH Viz DD v2 FULL SIZE COLOR TEST wc lines ca pdf save.pdf
