Deck Roof Huge Glitch
davidinvest
Go to solution Solved by Alaskan_Son,
  • Solution
Go to your second floor.  You'll see a wall with dashed lines where that gable should be.  Select the wall and open the DBX (dialogue box).  Uncheck "Invisible".  You may need to change the wall type as well depending on what you're trying to accomplish.
Also looks like you painted your walls, when I went to your siding 6 wall type it is a grey siding but your plan shows a brown siding, when changing siding type or color you should do it in the wall type and your can make different wall types
