Gable Wall Not Generating Siding.
davidlgoss
Hi. I have been playing with chief since 8.0 for little stuff. I just purchased x7& upgraded to x8 Drew house and when I changed 3 small bump outs to gable. The roof rebuilds to gables. But you can see through the fable to the materials behind. I tried deleting roof , re drawing and sizing those walls and rebuilding roofs. But same thing. If I start a new plan and do a rough outline same house. No interiors. Build roof. The gables behave as they should. I just had a bunch of time in this one. I did start the plan in x7. Could that be it
Help. Thanks a lot
Dave
had that problem in x8 beta, end of gables were open., had rebuild attic walls un checked. a lot of problems in x8, will not start anything till bugs worked  out. can't copy and change wall types, freeze up when generating material list after roof is generated. showing material in material list for second floor when there is no floor. doing gable walls as second floor, drywall and all
