Improved Cabinet Outlets
Alaskan_Son
Scott ordered some outlets that could be attached to island cabinetry (or almost any other item for that matter). The ones we have available in the library now do not display properly in both plan and 3D views without adjusting the origin. Once the origin is adjusted, they won't snap properly. Anyway, here are some that do all the above correctly. Created in X7...I just took the standard cabinet mounted outlets from the library and made some tweaks. Once imported they should be in your User Library in a folder titled "Cabinet Outlets".
Cabinet Outlets.calibz
  • Upvote 3
  • 2 weeks later...
  • 3 months later...
  • 2 weeks later...
