Reflective Metallic Drape
ericepv
Go to solution Solved by ericepv,
I am working on a project that has a large quantity of  silver metallic drape. I have been experimenting with different material typed and properties to get the most realistic reflective metallic look but so far I have not found a really good option. I tried using metallic or reflective material typed but I get alot of speckling and would need to add a lot of extra lighting which really slows down the Ray-Trace.
I have attached the material sample. Anyone have any suggestions?
Here I've had a play with giving several of Chief's
standard library items a "reflective metallic look".
If this is on the right path experiment with using
the Adjust Material Definition (rainbow tool) to
set the Material Class to Shiny Metal and in the
Define Material dbx start with; Specular - 50%,
Roughness - 0% and Reflection - 85%. These
settings should get you in the ballpark.
