Roof Eaves issue with skylights
gelbuilding
As near as I can tell, this is a flaw in the program.  The skylight "should not" be cutting a hole in the soffit of an overhanging roof above.  I think this should be sent in as a suggestion for change.  I have looked at as many settings as I could find for the roof and skylights and I haven't been able to find one that fixes this.  Strangely, the skylight will only cut a hole in the soffit above, not the roof plane above the soffit.  Go figure.
OK, where's Glenn .... he probably knows how to fix this with a setting somewhere?
  • 7 years later...
