Transparency Of Lines Possible?
tahoebrian5
I've found how to change transparency for hatch/fill but what about lines, either cad or part of objects? For example I like to shade back my electrical symbols if I include them on my main floor plan instead of a dedicated electrical plan. Another case is showing demo walls shaded back and dashed. I would much rather do this than try to find greyscale colors that look similar. It would be great if you could set transparency by layer but does not appear to be the case.
Brian,
You can change the LineStyle, Color, LineWeight and Text Style on a per Layer Set basis.  IOW, the same Layer can have different display parameters in different LayerSets.  Then, if you also use Annosets, you can specify the defaults for Dimensions, Text, Rich Text, Callouts, Markers, Arrows, the current CAD Layer and even the desired Layer Set.
