Simple Question About Elevations Display
tahoebrian5
I apologize in advance, it seems like the simplest things hang me up in the learning process.
Anyway, I have created my basic model and created the 4 exterior elevations which I'm nearly ready to send to my layout sheet. I would like to have just a simple black and white line drawing of the elevations. When I turn off color instead I get shading between the lines. How do I get a view without shading?
Ok, when I sent it to layout it displays correctly. Definite case of user error!
Next problem, I've chosen vector view which I understand allows object snapping to elevation lines. I can't get any snaps to work on the elevation except the bottom of the roof fascia.
What is your reason for object snapping in the Elevation View?
If it's for dimensions don't worry about it.  The Dimension Tools use appropriate Objects.
It does seem that Object Snaps should work to anything in the Elevation but only seem to recognize Roof Planes.  OTOH, they work to just about everything a Section View.
