Need Help With This Look
Electromen
Problem with frieze is that it won't cut out for the windows like a wall material region will.
As designers and builders, you usually try to avoid window trim frieze interference.....
From a practical standpoint, it would seem hard to accomplish this look without having the window slammed to the top to the ceiling and still trying to leave proper room for insulation.  (unless you were going to clip ceilings with furr-downs to accomplish this.)
Also...where does header go?  On top of TP?.   How does roof vent properly...ect.
Like I said, does not seem like a good detail for me.   Maybe 10-15 years ago when you did not have to worry about insulation out over wall plates extending to the edge of envelope.   Am I the only one seeing this?
