Can't Change Stud Spacing In Exterior Walls.
HaywardVT
Go to solution Solved by Joe_Carrick,
I know I can move the studs manually, but is there a way to set a default for exterior walls when auto framing? Every time I change the spacing it only changes interior walls and leaves the exterior stud spacing at 2' on center. I'm creating a double stud wall, so I've tried playing with the "framing" and "double wall" settings in the structure tab, but I don't see any changes being made when I change those settings.
