Stem wall height changes when building a parallel wall next to it.
HaywardVT
I am probably not the person to offer any help, but what I usually do is create a special wall type for similar situations I ran into on a project I recently completed. I just break the wall at the point where I need to add the interior wall, and then make it a special wall type (you know you can add layers as needed). At least that worked for me.
What exactly did you change with the wall types? And are you talking about the 6" or 4" walls? I tried wall breaks on both to try and fix it but it didn't help, and both of those walls are already custom ones I made. Wall breaks might be the way to go but I think I'm missing something.
