Stem wall has gap, won't connect to other wall.
HaywardVT
I can't figure out why it won't connect. I temporarily fixed the problem by adding the thickness of a stem wall to the length of the wall that has the issue, but after I continued working I noticed it again. Also, if I double click the wall to open the spec box and hit ok without making any changes, the gap changes which side it's on. I have no idea what that means or if it will help when trying to solve the problem.
Johnson Lot 43.plan
