18'-0" Tall wall with Doors and windows
OkcDesigner
I think there are several ways to get what you want:
First:  Use window levels to control what shows at the four foot plan section cut level.  The windows above will show, but be grayed out.  The upper windows can be made to to disappear if you put it on an separate layer, and give them an invisible line style. The label will still show.
Second:  Use a pony wall set at about the eight foot level (or wherever you need it) to control what shows above, and below.  This is probably the best method. All labels will show, and you can toggle between the upper and lower windows in the wall DBX.
Third:  Use two floors, with the upper floor being "open below"  Use the reference layer to bring the label for the upper window down to the first floor.
