stone walls with rounded interior window jambs
Dennis_Gavin
There was a lot of information on methods to do this in the old thread.  Does anyone remember what worked the best?
I think one was a thinner wall with the window and then PS to fill in on the sides.
I think another was custom casing.  Not sure if the thinner wall was used in both.
Anyone remember or have a link??
I can get it with one wall and the use of four p-line solids...
Not sure if it's what you want or not...but looks somewhat right.
-Made my window 12" wider than I wanted.
-Removed exterior and interior casing
-Turned on the interior sill
-Turned off frame
-Inset my sash something like 1 1/2"
-Made the sides of my sash 6" wider than normal
-Drew a curved polyline solid for the inside, and just a plain polyline solid box for the outside
-Adjusted them to fit the height
-Copy and paste-hold the solids
-Reflected about the center of my window
I also attached my plan so you can dissect it...
Windows.plan
OK, so I have settled on thinner wall sections and PS fills.  Now I cannot get a window to move.  IF you look at the plan one window is off center and I cannot get it to move even though there is room for it to do so.  I think I am losing it.
Edit - If I copied the existing window and placed it into the thinner wall section no can move.  However if I put in a new one from the library it centers fine.
         Weird......
Miller.plan
Dennis,
Here is a link to a post on the old Forum that takes up this subject. In it, Bill Emery posted a plan with his method for accomplishing what I believe you are looking to do.
http://www.chieftalk.com/showthread.php?64641-How-To-Create-a-Deep-inset-Window-With-a-Stucco-Wrap/page2&highlight=drywall+wraps
And here is a link to a similar discussion on this Forum (with a link back back to the old Forum).
https://chieftalk.chiefarchitect.com/index.php?/topic/4465-unique-door-and-window-trim/
Hope this helps.
Hi Dennis,
I've taken a little different approach to the problem.  I've used a double wall and have placed a window in the outside wall.  I then placed a pass though window on the inside wall, and centered on the window in the outer wall.  I can maintain an unbroken wall in this way.
I've used a deep sill in the outer window, and have added the rounded portion of the opening using "shutters" in the shape of a quarter round. They are mostly adjusted in the window DBX.  The round is a millwork symbol with a -12" Y offset.
The window pair can be copied around the plan, and resized as necessary. The window pair can also be added to the library.
Dennis Gavin's window.plan
Thanks Bill, I'll have a look.  I was thinking after I wrapped up the day yesterday that maybe a railing wall section with the cap adjusted would do a similar thing.  But it would require
creating that wall portion for each window section.  I think yours may be the best approach in allowing copy and paste.
Thanks!
