Steped Foundations
ACADuser
OK the job is finished but then the Developer wants the foundation wall height minimized & the footing will be in the fill.
So on one side of a courtyard, the garaged is detached but privacy walls connect the house & courtyard so the privacy wall foundations now need to be stepped up several times. And the house foundation shortened on 3 of the 4 sides. I don't want to move the grade & rebuild the foundation. How to break the foundation & move each section up?
While in elevation view, click on the wall, hit the number "3" on your keyboard.  The 3 is the shortcut for "Break Line". Then click on the bottom of the wall where you want a break in the foundation.  You will then have another grab-handle on the bottom the wall.  Grab it and pull that section higher.
