Cabinet doors with custom mullions
Clare_White
Clare, I'd call that a glass panel insert as opposed to custom mullions.
What I'd do is create a custom material, created from an image I found on the internet.  I'm sure you could find some images of leaded glass that would work - do a search for Queen Anne leaded glass.  I've attached an example of one I found - use it to make your material
Once you make the new material simply use it for the panel section of the door.  If you really need the transparency it's a little harder but for a basic image or quickie rendering, this would work.
