Delete Custom Linetype
buzzsaw204
When you create a new line style it then appears in your Library Browser in the "User Catalog" area where it can be renamed or deleted.
yes, i created and do see it. it's in "appears in your Library Browser in the "User Catalog" area"
and i have deleted it in here.
but is still appears in the LT in the drawing.
i want to PURGE it in the drawing.
Are their any lines in the plan utilizing the line style?    When I created the unique line style and applied it to a line and then deleted it from the library, It would still appear in the DBX.   Once i deleted all of the lines in the plan, closed CA and reopened the unique was no longer in the DBX.   I will say it is a pretty tricky !
yes. i do realized that if a linetype is used in the plan, then it can not be purge out the dbx.
but i have tested that. deleted that unique linetype in the User Catalog, and delete all used line in the plan.
then Save, close and reopen...but is show in dbx
