Bath Symbol Issue
Kbird1
Hi , working on a Bathroom Reno today , and I am not sure if this is new Or I just haven't noticed it before , the Standard Tubs in the Library always need resizing as they aren't 5' long and most Tubs nowadays are Taller at 20-22" whereas in the past 15-17" was common, so I always have to stretch/resize them but after doing a Camera view, it took me a while to figure out that the upside down "L" on the end of the Bathtub was actually the Overflow, since I had made the bath 34" in deep from 30 and 22" Tall from 17", the issue is effecting the Drain too.
I am assuming this is a stretch plan issue so am hoping someone knows the Trick to have the Drain and Overflow stay Centered and their original size.
I tried Standard Bath 2 and 3 , with and without Faucets and the issue is the same.
Thanks
Mick.
Much appreciated Graeme :)
I  converted those to approx.inches  ,which is -26 1/2" and -7" , under depth, and that worked great, just be sure to set the stretch planes before resizing as it doesn't work retroactively it seems.
Mick.
