Recessed Crawlspace Slab
BuildingDesigner
Is it possible to show the Crawlspace Floor below the top of the footing?  I've tried and it keeps lowering my footings automatically.
I've done a work around by drawing the slab manually but wanting to know if it is possible to do it using the software settings.
Not a big deal as it is a one off issue.
I don't think Chief likes to do it that way ... likes to keep the slab on top of the footing.  Easiest IMO is to draw your slab in manually and set the elevation as needed.  Maybe there's a way to trick Chief and get it done ??? .... If so, I don't know of it.
