Copying an entire plan
shanecarman
Open both plans.
Go to the plan to copy; zoom out until you can see everything; then Edit>Edit Area>Edit Area (All Floors) & draw the marquee around everything; then Edit>Copy.
Go to the plan to paste; then Paste.
if you need to build/rebuild roofs separately
or have complex terrain
I find it easier to keep the plans separate and make a 3D symbol of one of the houses
add it to the library
then add that symbol to the "master" plan
Lew
  • 2 months later...
Shoot an orthographic overview then Tools>Symbol>Convert to Symbol.
Yep.
And a tip for after:  Your window glass will not raytrace the same.  Glass in windows in chief is "magic glass", but not in symbols.  Use the Rainbow tool to select glass in your symbol, material properties tab, turn Reflectance and Transparency both up to maybe 75%.  Otherwise you'll get this flat greyish window thing.
