Sizing cabinets to fit in wall to wall alcove
ChiefTyler
I am creating an alcove the steps back 2' and is 8' and the floor to ceiling cabinets will be place wall to wall in this space.  Is there a way to select all and size them all to fit as opposed to manually dividing the space and individually spacing the cabinets?
Thanks in advance!
Well there is a way but may not suit your needs.
You can stretch a cabinet to whatever width you want, then divide the front into however many sections you need, then use the equalize button -all in the dbx.
I'd add fillers to both sides going wall to wall, and trim at the top when going to the ceiling.
The question remains whether or not that will be representative of how it will be built. If you are looking for multiple cabinets then what David said.
