Drag handle not working (X6)
Ross101
Hi All
This must be justt me or a new setting somewhere......... I can't believe nobody else is having this issue.
I just downloaded X6 and am using it for the first time.
I open a plan and insert a window.  I then go to a 3D view (eg, full camera) and select the window.  I have no trouble selecting the window in 3D, but when I try to adjust its width or height or position I can't select any of the relevant drag handles.  I can see them, But I just can't select them.  Similar story with other items (furniture, walls, etc).  I have the "Select Objects" icon ticked. The only way I can find to adjust objects is to open them and use the dialogue box........ What am I missing??
Thanks
Ross
Bill, that was it, thanks.
My settings were as follows:
Edit Handle Size = 3
Edit Handle Tolerance = 1
I changed this to:
Edit handle size = 8 (made the edit handles about the same as they appear in X5)
Edit Handle Tolerance = 0 (the recommended default setting in Help).
All OK now.  Thanks again.
Ross
