• ×   Pasted as rich text.   Paste as plain text instead
      Only 75 emoji are allowed.
  • Member Statistics
    27620
    Total Members
    6254
    Most Online
    edos301
    Newest Member
    edos301
    Joined
  • Similar Content
    • By Designer100
      Does anyone know why my pier and beam foundation floor joists and beams disappear when I try to do perpective and I have to back out of it? Open old one! I custom drawn floor joist and pads and 1 concrete block on each pad then drew beams and floor joists. I keep trying to pull siding down over to cover the beams and floor joists and then they all disappear. I need the floor decking to appear on a section over floor joist to with deck up level with entry and grass under home.
      I did this project in Chief x11. I would appreciate any help in this apartment.
      Thanks
      Newell Cheatheam
      Katy,Tx. 77450
      newell.cheatheam@gmail.com
      713.385.3622.
      Apartment_Plan.plan
    • By PPRGLLC
      I'm trying to change the material for the trim alongside my stairs independent of the riser material. I want the trim to match the baseboards in the rest of the house and the riser to match the tread. Is it possible to separate the trim and the riser material in the stair definition dialog?
    • By Designer100
      I have designed a pergola and a deck. I cannot get the terrian to show right. It needs to be zero of level at back of deck by pool deck and slowly slope down to a bayou. it needs to be 36" to grade at edge of outer deck Then a stair going down to the end of stair which is around 5 fr lower that top of deck. I have not did much terrian and would appreciate your help. This is just a remodeling and adding a deck from the pool.
      Thank  you,
      Nerwell
      Pergola_.plan
      11X17.layout
    • By DeckQuestions
      Is there a way to make the top rail of my deck railing rounded?
    • By ChiefArchitect
      Option 6 is large enough to provide extra family space in the form of a loft on the 2nd floor. For this house style, we put a balcony over the porch and front door, making this sunny room even more welcoming.
