Window & Door Labels In Elevations?
ACADuser
OK 5 day count down to vacation & I'll get out of your hair for two weeks ;)
Two questions:
Attached is an elevation with the window labels turned on, some in mulled units.
The labels are obscured by the mullions, any cure for that? Do i have to drag then all out of the windows? Not much room to work with.
Question 2: I am using the elevations @ 1/4 scale with text created in the elevation & send to layout for standard elevation views.
I am also using the elevation with a different layer set to turn off the text & turn on the window & door labels & send to another layout 1/8 scale on my schedule layout page.
Is this the proper way to separate the elevations? Meaning use a second layer set. Or should I have created another elevation view with a second camera & also a second layer set.
The only way to update the layout view is to close the elevation, right.
I know that is a third question. So I open the elevation camera, set my layer set & close it to update the layout?
But this doesn't work, the labels disappeared. I'm confused as usual.
It's a matter of knowing what you are doing.  Each Layout Box has a Layer Set.  If both are using the same Layer Set then that's what you get.  You can select one of the Layout boxes and assign a different Layer Set.
The other way to handle this is to "Copy the Layer Set" when sending to Layout.  That will insure the Layout Box has a unique Layer Set of its own.
This would be I first one.
Thank you Scott!
And one more point because I am in a giving mood.
Guess who I get to visit Saturday?  Yes,  that is correct,  Jim "I Fought the Lawes" Lawes.  He is going to take us golfing up in Michigan.  I am so excited.  Now if Jim was going to take us out for two days,  I just might give you two points.
I created a separate layer set for each condition & the two have the proper layer set but when I regen while closing the elevation view it generates twice & both layouts are the same.
I grew up in Michigan. Great place to be from! Tell I loaded up the truck an move to Beverly's.
It appears as though creating the layout view with a copy of the layer is the only way I could get it to work.
Thanks
