Planning a Remodel, ADU or New Build? Start With a Free Project Snapshot
Ordoworx
If you’re considering a remodel, ADU, addition, new home, or another residential project, Ordoworx is offering a free Project Snapshot to help you understand the property and permitting picture before you move too far into drawings or applications.
The Project Snapshot will provide an initial look at:
  • The county and likely permit jurisdiction
  • Readily available property and building-record details
  • Preliminary build-size assumptions
  • Published size or fee thresholds that may affect impact fees
  • Visible utility questions involving water service or connection, gas, electricity, and septic or sewer
  • The key information that should be confirmed before permit drawings or a permit application proceed
The goal is to give homeowners and small-scale builders a clearer starting point — so you know what appears straightforward, what may affect the project, and what needs to be confirmed before investing further in design and permitting.
Ordoworx helps coordinate the information between owners, builders, drafters, consultants, and the permit process while identifying items that require confirmation by the appropriate jurisdiction or licensed professional.
Learn more and request your free Project Snapshot here:
https://ordoworx.com/about
If you have a residential project in the early stages — or one where you’re not sure what needs to happen next — send it over and we’ll help you get a clearer picture.
Ordoworx_Capabilities.pptx
Edited by Ordoworx
  • Downvote 1
That early review can be especially valuable when a rural project is going to need an onsite wastewater system. Septic requirements can depend heavily on the actual property, including soil conditions, available dispersal area, setbacks, and the proposed use of the building. For anyone trying to understand what goes into the septic side of the project, the site evaluation and design process outlined on this page is a good example of the work that may need to be completed before permitting and installation. Getting that piece assessed early would definitely help avoid redesigning the broader project around septic constraints later.
Edited by thadius
  • Upvote 2
Most of it can usually be pre-assessed before you submit anything.
If we have the basic project information — such as the APN, estimated construction cost, project type, and approximate square footage — we can usually build a fairly complete preliminary picture of the permitting path.
That can include:
  • which city/county departments are likely to review the project
  • the applicable fire and school districts
  • likely utility or health-department involvement
  • a ballpark permit-fee range
  • known or published impact-fee triggers
  • obvious thresholds that may affect school, fire, utility, or other development fees
  • the main items that should be confirmed before drawings or an online application are started
So the goal is to identify as much of the permitting landscape as possible before the first online submission is even filed.
There will always be items that only the jurisdiction can formally confirm, but in most cases we can eliminate a lot of uncertainty upfront and give you a much clearer idea of what the project is likely to encounter.
  • Downvote 1
