Wall opening problem
JeanTurcotte
never noticed the small triangles before , do you have wall breaks there perhaps? did you try deleting the opening and redoing it?  did you use a "Doorway" or did you just Stop the walls either side when you made them?
I agree that wall definition could be the problem. Here, we are using Autocad to create final drawing plans (more userfriendly). My starting question was why this problem appear only with X6 release ? we never had this problem with prior release. Is there something easy to do to fix it without put doorway ?
