Dimension External & Internal Wall Frame Only Without Wall Layers
BrianD
Can someone clear my head about this .
To dimension External & Internal wall frame only without wall layers , what selections should I make in the
diminsion defaults dialog box.
Thank You
Brian Dominick
Chief X7
Win 8.1 SSD
Bill
Thanks for your reply. What you recommend was as I had chosen myself.So looking further I looked at the "wall type definition box" and noticed that I had one wallboard layer in with the main layer area with the air cavity layer. Moved the wallboard down and now ok. Sometimes just asking gives one a wake-up call.
Thanks for your help
Brian Dominick
