Help with changing individual roof pitches
BeeoHat
Go to solution Solved by glennw,
The roof pitches of my house differ from the first to the second floor. The pitch on the upper roof section is much steeper than the sections on the first floor (front and back of house). When I generate a roof, all sections have the same pitch. How do I adjust individual roof section pitches??post-567-0-11186300-1395255555_thumb.jpg
I believe you can control individual roof planes by clicking on the wall below the roof plan you want edited, then click on the "roof" tab and then type in your desired pitch in the "pitch options" area... Hopefully that makes sense...
After many attempts, I managed to  change the roof pitches as needed. The trick seemed to be, make sure ALL walls sections that are under that roof section have the pitch changes made. As usual, thanks to all for your great input.  :)  :)
