Arched or Barrel Ceilings
tantrim
The easiest method would be to take a cross section of the room.
Draw an arch (barrel) using the CAD tools.
Convert it to a molding polyline with a thickness of say 1" times whatever the length of the room is.
Now ain't that a clever solution. I like it.
Methods for building barrel arch:
-ceiling  plane
-psolid
-2d molding
am I forgetting another method?
Scott:
The beauty of the pmolding is it auto gives you both sides of  the drywall whereas the poly solid does not
You could make your PL solid look just like a sheet of drywall if you wanted to take the time to do it.
