sthieldesign Posted May 12 Share Posted May 12 I usually export my files in DWG to Architects no problem. An Architect told me that when he tries to open it says that the file is an unsupported version of Auto Cad. I did the export on his supporting year AutoCad as well. Is this new with X15? How do I export DWG files? Thank you! Susan Link to comment Share on other sites More sharing options...
BenPalmer Posted May 12 Share Posted May 12 A couple quick thoughts: does it still allow them to open the file? when I open files in Autodesk's free viewer, I get that message but can still open and work with the file just fine. If above doesn't solve it, possibly try exporting to an earlier version during the export process Try exporting to a DXF instead Report back and let us know...this will help all of us. 1 Link to comment Share on other sites More sharing options...
Kiwideziner Posted May 12 Share Posted May 12 It just means it has not been generated by an AutoDesk product. It would appear that this has been the case for 2 or three versions of Acad. I have found no problem opening any of my files. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 12 Share Posted May 12 (edited) It seems to me that we are talking about something different than this : As "this" has been happening as long as I can remember. Actually I just installed TrueView 2024 and it still works the same way with an X15 exported file. Edited May 13 by Chopsaw Link to comment Share on other sites More sharing options...
Kiwideziner Posted May 14 Share Posted May 14 That's the dialog I was thinking of Link to comment Share on other sites More sharing options...
JKEdmo Posted May 15 Share Posted May 15 On 5/12/2023 at 12:59 PM, sthieldesign said: An Architect told me that when he tries to open it says that the file is an unsupported version of Auto Cad. If your architect uses an older version of Autocad, you can advise him/her to use DWG TrueView 2023 from Autodesk to convert the DWG to a compatible version. It's free from Autodesk website. For example, I get often files in latest version of Autocad from a client, but I work with Autocad 2015. But, I can use TrueView to "down save" to my version. Use the "DWG Convert" option of the program. Jim Link to comment Share on other sites More sharing options...
Steve-C Posted May 15 Share Posted May 15 I've had this problem before. I had create a CAD detail from view then export and it seemed to solve the issue. 1 Link to comment Share on other sites More sharing options...
sthieldesign Posted May 17 Author Share Posted May 17 Thank you so much! I am waiting for the Architect to try these methods and will let you know! Susan Link to comment Share on other sites More sharing options...
