Arcadian Posted February 16 Share Posted February 16 Hi All, Trying to adjust a pair of exterior French doors with door larger than the other. I assume the adjustment will be the custom button which is not activated so can't select it. Any thoughts? Link to comment Share on other sites More sharing options...
Dermot Posted February 16 Share Posted February 16 The short answer is that the "custom" option is only enabled for sliding, pocket, or bifold doors. For a more complete answer (including some workarounds), see this prior thread: Link to comment Share on other sites More sharing options...
Arcadian Posted February 16 Author Share Posted February 16 Hi Dermot, Got that. Thanks for the assist Link to comment Share on other sites More sharing options...
glennw Posted February 16 Share Posted February 16 The easiest way to do 2 doors of different sizes is to just butt them up against each other. They will auto mull together - no need to manually mull them together. Make sure Minimum Separation in the window defaults is set to zero - this setting applies to both windows and doors. You retain full editing capability for both doors. 1 1 Link to comment Share on other sites More sharing options...
Arcadian Posted February 16 Author Share Posted February 16 Thanks Glenn, yes that works !! Link to comment Share on other sites More sharing options...
