RFA conversion help!
dskogg
Go to solution Solved by SusanC,
  • Solution
If you're in hurry, another option is to use the Wolf ceiling hood which is flush mount and looks similar to the Nuvola 90 when it is installed up in the ceiling.  You can find it in Chief's Wolf Cooking catalog.  If you need to have your schedule populate correctly, you can just go into the dialog box for this hood and change the name, the specs, etc.
Good luck!
Good luck!
Thanks Susan, this will work nicely, didnt know it was there.
