render is completely black!
mrhoseindanesh
Go to solution Solved by mrhoseindanesh,
1 hour ago, mrhoseindanesh said:
16gb ram
2g asus graphic
i5 9600k
Would that possibly be a laptop setup ?  Check to see what graphics card chief is using.  Preferences > Render  > Video Card Status
Something may have caused that to change to using the integrated video driver rather than your 2 GB Video Card.
25 minutes ago, mrhoseindanesh said:
thanks sir...no it is pc.but i didnt buy new graphic card because prices are too high here.any way this problem never happened before  just happened in this project.think this pic is what you need
The 2 GB card should be adequate since you are running X7 so have a look through this trouble shooting article and see if any of the suggestions work for your setup.
https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html#RenderPref
Is this a more detailed plan than anything you have done previously ?
