Walls Short of Shed Roof
OrinCrowder
Go to solution Solved by Kbird1,
Can't get these exterior walls to come up to the roof. Tried all the wall / roof options and tried deleting and rebuilding the attic layer. Same thing happened with a full shed roof rather than this version that creates a gable roof over the second story porch area (that is clearly not completely worked out). Any help is much appreciated. Thanks.
  • Solution
2 hours ago, solver said:
Edit>Reset to Defaults
Then Try Ballooning the Walls Up in their Structure Tabs.
* you do have Auto Attic Walls Enabled right?    >  Press Alt-Q (general Wall Defaults shortcut) and see if it checked.
Mick.
