List of Callable Ruby Object Attributes
Allen43
I have returned to this forum once again in seek some help with ruby and macros.
I have been working on a macro to automate cabinet labels. So far I have a mostly working macro, but I feel like my hands are tied and my eyes are closed. First of all the documentation on chief implementation of ruby and its capabilities it really lacking. And second, I don't have the Ruby terminal. I think this is because I am running Interiors, but am not sure as all Chief says is that there is limited use of Ruby in this version.
Anyways, right now I would love to have a list of all callable object attributes. I honestly don't even know if that is the right name for what I am looking for. I am trying to find a list of what info I can scrape from a cabinet. So, what can I put after obj. (ie. obj.width, obj.type)? I think I could find this by running the selected.names command in the terminal, but I have no way of knowing.
This is my current macro. It is built from parts of a macro from @MarkMc and whatever I have been able to come up with from random trial and error. If you see something I could improve on, I am open to suggestions as long as they have a good explanation with them. Thanks in advance!
Macro:
obj = owner
obj = referenced unless referenced.nil?
obj.depth
type = obj.type.to_s
nf = NumberFormatter.new
nf.unit = 'in'
nf.use_fractions = true
nf.show_unit = false
nf.apply(obj.depth)
standard_size = 24.0 if type == 'base_cabinet'
standard_size = 12.0 if type == 'wall_cabinet'
standard_size = 24.0 if type == 'full_height_cabinet'
depth = nf.apply(obj.depth) if obj.depth.to_f != standard_size
standard_size_height = 36 if type == 'base_cabinet'
standard_size_height = 0.0 if type == 'full_height_cabinet'
height = nf.apply(obj.height) if obj.height.to_f != standard_size_height
width = nf.apply(obj.width)
nomen = 'B' if type == 'base_cabinet'
nomen = 'W' if type == 'wall_cabinet'
nomen = 'T' if type == 'full_height_cabinet'
hinging = owner.door_swing
label = ""
label << nomen << width.to_s << height.to_s << depth.to_s << hinging
p label
Here's a macro you can import and then use to check what NVPs are available for whatever object you select.  In order to use it:
  • select an object
  • open TMM and select the _Object_properties_expanded_sorted_wo_default macro.
  • all of the NVPs for that object will be listed in the lower right panel.
This is one of the most important tools I have for creating macros.
Object Properties.json
2 minutes ago, solver said:
You might say what you are doing in your macro, and it's probably helpful to document your code (I know it is for me) so you can understand what you did in a year when you need to make a change.
Yeah, I would love to but have not found a way to comment out a line. I know it has to be simple but every time that I look it up I get ruby implantations in a IDE and from what I can tell non of those methods work in chief's ruby implementation.
Do you know about the object_properties macro?
No I did not, but I will definantly check it out now.
  • select an object
Thank you!! I will give this a look, but from the name it seems like exactly what I have been looking for.
You are testing the same value multiple times. I'd consolidate like this. This isn't complete, just done to give you an idea.
case obj.type.to_s
when 'base_cabinet'
  nomen = 'B'
when 'wall_cabinet'
  nomen = 'W'
else
  standard_size = 0
  nomen = 'error'
end
Thank you!!! I have been dying without when and else statements. Believe it or not, but I do know how to code in other languages. I don't know why this one is throwing me for such a loop.
A hashtag works in Chief.......
# MACRO EDITED/CREATED BY MICK @ MHD
# All Code "found" on the CA Forums and altered to suit as needed
# Credits to Eric (Solver), Michael (AlaskanSon) and Joe_Carrick
#Initalise Macro
referenced ? obj= referenced : obj=owner
result = ""
Here's my version of the macro.
# Macro Name: cab_label
#   OBJECT type width depth height swing
referenced ? obj = referenced : obj = owner
slabel = ""
slabel << obj.type[0].upcase.gsub("F","T")  # convert Full to Tall
slabel << obj.width.to_f.round(0).to_s
slabel << obj.depth.to_f.round(0).to_s
slabel << obj.height.to_f.round(0).to_s
slabel << obj.door_swing
Nothing else is required
