Fascia Missing
Ange822
Good afternoon,
I am having issues with a fascia board missing.
I have tried re drawing it, moving it up / down / side to side slightly and nothing seems to work.
Not sure if this is an easy fix but I can easily draw a polyline!
Thanks in advanced.
Hard to tell from the pic , you haven't just assigned the wrong material to it have you ? ...looks like siding to me in pic...
another thought -  have you rebuilt the framing ?
otherwise as Rob said you might need to post the plan.
The fascia and roof edge(s) of gable end return and primary gable appear to be at the same elevation.
The attached may or may not be the desired look, but it works. The primary roof can be "broken" along the rake boards so that a hip roof section can be created with the gable end return.
Note: Per Rob and Mick, you should probably post the plan file. In X-14 what your plan file is showing has been a bit of an anomaly. The fascia on the gable end return should exist, even if it doesn't merge with the rakes on the main gable.
