Pond Boulders or Rocks
aereed82
1 hour ago, aereed82 said:
Does anyone have anything they can share for rocks going around the edge of a pond. I have to ponds to line the edges and don't want to draw them all by polylines.
Did you check for Rocks in the Core Library?
12 minutes ago, Designers_Ink said:
There are several in the 3D warehouse I use.  Also, remember you can copy them and vary them my resizing and shaping the same rock and using different textures to make the rocks look more realistic.
Try a distribution path as well.
Yes, It does not have what I'm looking for.
Like Ryan and Jeff suggested, 3D Warehouse have some, BUT what I have found and tend to use quite a bit is located in Chiefs Bonus Catalog, Backyard Ponds and Water Features.  In this folder, under Pre-configured Ponds, is a Koi Pond Block.  It has various rocks and shapes.  I explode it and use the rocks where I need them..
No harm to the Koi BTW...
9 hours ago, solver said:
And maybe you want riprap, not riffraff.
I don't know Eric... If the OP is looking for a riff-raff
kind of look he just might be in the right place. :ph34r: ;)
There are river rocks and gravel in the Core Library if that will work for you.
