Another Roof question
CaptShip
Trying to add a shed roof over a 12 X 12 addition using 2023 Architectural version.  The shed roof is to match the opposite side of the house shed roof, pitch 6.
I am a new user. I was able to accurately model the existing house, but getting the roof over the new section has me kerfuffled!  I have multiple hours in so far without any luck, have made a lot of really odd roofs though.B)
I know if I spend another $400 I can get the pro version and manually create a roof, but that is a pretty steep price for a one-off use.  I only need to be able to model as close as possible to be able to demonstrate the concept and relocate the 2nd floor window the shed roof will dissect.
Attached a zipped file of the design if that is useful.
Greatly appreciate any and all advice!
Steve
419 old sherman mod 2.zip
Hi Mark,
I must have done something wrong as I did not see any differences.
Hi Eric
thanks for pointing out the correct forum.  Will head over there.  Suspect only solution is to upgrade to pro though.  If I rent pro for a month will the file I create open in Architectural afte the rental period is over?
