Edge of stucco wall shows framing rather than stucco.
weverett50
Most houses I design are pueblo style which have varying heights of parapets.  When I have a variation in height, the edge of the wall shows framing rather than stucco.  These extra lines mess up the elevation views as well as when I show the customer in 3d.  Anyone have a remedy for this?  Thank you!
Most common methods would be using:
Moldings
Wall Caps
But you can also use:
3d Solids
Roof Planes
Ceiling Planes
Cabinets
hmmm probably forgetting about 20-30 other methods that are more creative..
If the stucco is an exterior layer, Chief should wrap it around the edge. However, for a parapet wall, you could use a pony wall and a different wall type for the upper portion that has stucco on both interior and exterior (or a waterproofing layer on the interior).
Or, you can edit the parapet walls on the attic level.
That's how this was done, and I used a wall cap molding for the top.
View from on the roof:
