Locking Existing Framing
DougDM
Go to solution Solved by basketballman,
20 hours ago, solver said:
What happens to the deck when you reframe?
Hey Eric, It's an As-built...the existing deck ledgers are bolted through Brick veneer to rim joist of house.   If I do an auto frame or re- frame basement ceiling (1st fl. floor framing), CA re-frames the deck through the brick and puts the ledgers against existing framing, as if brick didn't exist.   I manually framed it and don't want it changed or re-framed the way CA wants to... which is wrong. Thanks for looking,
Doug
