3-wall (open) foundation? is it ok? or bad in practice?
SalemSchool
Go to solution Solved by Farrell,
This is for a walkout basement.
Is it bad practice to have just 3 walls of foundation and thus frame the wall the walkout is on?
I'm wondering if this would be a lot of torque at the opposite corners (red circles) from the gravel backfill pushing in on the foundation walls (red arrows)?
(Note: there is a concrete frost wall below the wood framing on the walkout side)
See attached picture.
Thanks guys.
NRST8TRKR, the reason I'm concerned about the stress on the walls is that there will be a retaining wall at the left and right sides of the walkout so the grade won't drop as much as typical, thus having a bit more pressure from the backfill.
