Full height cabinet pulls issues
J_Ward
Go to solution Solved by RobUSMC,
Is there any way to fix the handle placement on tall (full height) cabinets. There needs to be a setting for "down from top" and "up from bottom". Or I'm just doing something wrong here.
Please see attached.
  • Solution
You can also leave the top a door. Make the bottom a drawer but use the same matching door front as a drawer face then you can move the hardware independent. I do this all the time and it works fine.
