Cadman_97701 Posted August 5 Share Posted August 5 Hello, I'm new to CA. Been using for about 6 months now. I've come across an issue I need help with. Please see attached files for explanation. Thanks for your help!! Lyle Splenlinhauer Wychles Proposed 2.pdf Splenlinhauer Wychles Proposed.pdf Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 5 Share Posted August 5 IF you want them to show in camera views but not plan view, while in plan view select the wall that you do not wish to see and make it invisible in the Plan View Layer set, it will still show in camera views. You may need to segment the wall so just the part that you do not want to show in plan view is (wall break tool) cut off from the rest so only the part you do not want visible in plan view is then make "invisible". DJP 1 Link to comment Share on other sites More sharing options...
