Shift A Dimensions
edcsteve
Auto Exterior Dimensions Should automatically remove and replace any previous Auto Exterior Dimensions unless you have previously edited those dimensions in any way.  Per the Help files, any edited dimension "...will be marked as edited, so if Auto Dimensions are later regenerated, your changes will not be lost."
